Suspension & Brakes Theory, alignment, spring rates....
11" Prelude Front Brakes on EG?
Old Dec 15, 2010 | 06:51 AM
EM2Builder's Avatar
Default 11" Prelude Front Brakes on EG?
By hanging onto incredible amounts of car-part junk..... I've accumulated 95 Prelude VTEC calipers and 11" rotors redrilled for 4x100. I thought this would fit my 95 Civic EX Coupe, but the ears on the knuckles are too short to attach the caliper bracket over the rotor.
I haven't been able to find any info on this, but what can I do to make this setup work? Can I swap 96+ knuckles? Different calipers or brackets?
Old Dec 15, 2010 | 07:21 AM
roastbeefrichie's Avatar
Default Re: 11" Prelude Front Brakes on EG?
keep the 92-95 civic EX front knuckles
your 95 prelude VTEC front calipers should be stamped: 1 7 C L 1 5 V N (identical to ITR calipers)
Originally Posted by roastbeefrichie
if you're interested in the ITR caliper upgrade, you'll need to source the calipers first.
the ITR caliper is stamped 17CL15VN
the 17CL15VN is one of the biggest single piston calipers honda produces.
you can easily identify this caliper from the stamp.
this caliper can also be found on:
97-01 ITR,
97-99 CL V6,
91-95 legend,
96-98 rl,
95-98 tl,
92-94 vigor,
95-02 accord v6,
91-97 accord wagon,
97-01 crv,
95-01 odyssey,
92-96 prelude vtec
& 97-01 prelude
Old Dec 15, 2010 | 07:23 AM
your problem is offset, if you've already tried to "test-fit" you'll find that you're going to have trouble clearing
you can solve this by:
a. using shims
b. machining the brackets for clearance
* i prefer the machined method *
once you obtain the calipers, you'll need to seperate the caliper bracket.
the bracket is stamped either 23T, 25T or 28T.
the bracket will need to be milled 2-3mm (or 1/8").
* (the machined brackets will also accept NSX & 94-95 legend 2-pot front calipers)
Last edited by roastbeefrichie; Dec 15, 2010 at 08:12 AM. Reason: machined brackets
Originally Posted by BrakeExpert,
Old Dec 15, 2010 | 07:24 AM
Orginally posted by BrakeExpert,
Old Dec 15, 2010 | 07:25 AM
prelude calipers on EG: http://htarchive.org/showthread.php?t=2765190
Old Dec 15, 2010 | 07:43 AM
once the machine work is complete, everything should be a bolt-on process
* no upgrade to your 95 civic EX's master cylinder necessary *
after caliper installation:
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
Old Dec 15, 2010 | 05:11 PM
EM2Builder's Avatar
Thanks for all the info! I checked and I do indeed have the 17CL15VN calipers.
It looks like in this post the guy is using Integra knuckles on his EG, are those the same as the EX knuckles? I can get the brackets bolted to my knuckle with the rotor off, but with the rotor on, the bracket hits the rotor before the holes align with the knuckle ears.
Old Dec 15, 2010 | 06:38 PM
1. It looks like in this post the guy is using Integra knuckles on his EG, are those the same as the EX knuckles?
92-95 civic EX and 94-01 integra (non-ITR) share the same brake upgrades,
yes, that thread applies to your application
as mentioned in my previous post:
a. using shims
you'll need to seperate the caliper & the bracket
the bracket needs to be sent out to a machine shop & will need to get milled
oneoffaccord
Sep 22, 2010 01:39 PM
tooth_dr
Suspension & Brakes
May 3, 2009 12:25 AM
Powelly
Oct 11, 2007 04:59 AM
AudioXtremes
Apr 10, 2006 04:27 AM
