what would be the best sander to prep your car
Old Dec 14, 2010 | 11:28 PM
FTNW's Avatar
Default what would be the best sander to prep your car
iv looked around
.. havent found too much useful info
finishing sander?
belt sander?
hand sanding ?
also if you could give me any recomonditions as to brands and what not too that would help
Old Dec 15, 2010 | 12:34 AM
MindBomber's Avatar
Default Re: what would be the best sander to prep your car
A belt sander would go straight to bare metal in seconds lol
Old Dec 15, 2010 | 06:24 AM
JDM 98 GSR's Avatar
what kind of prep work are you talking about? is there body work? or are you just sanding it to respray it?
Old Dec 15, 2010 | 07:17 AM
BarcodeCRXSI's Avatar
It will be awesome if someone made a FAQ or DIY thread about prepping your car for painting. Whether it be fore a simple repaint to complete repaint by sanding down to the metal.
Old Dec 15, 2010 | 11:31 AM
Psychoteen101's Avatar
http://www.matcotools.com/Catalog/to...select=&page=2
Look at part number- MT4151 (Random Orbital Sander)
This is the best "all around" sander ive found. Wont do everything you need, but it will do most. Its not as destructive as a DA sander which is why i like using it.
Old Dec 15, 2010 | 12:03 PM
jasoncrashtech's Avatar
da with interface pad for paint prep.
Old Dec 15, 2010 | 01:42 PM
FTNW's Avatar
are all da sanders air powered ?
Old Dec 15, 2010 | 02:36 PM
i have never seen a electric powered da before.
Old Dec 15, 2010 | 05:57 PM
FTNW's Avatar
i was thinking about using a black and decker mouse sander
Old Dec 15, 2010 | 07:48 PM
shocker911's Avatar
i wouldnt....what are you trying to do would help as well
Old Dec 15, 2010 | 08:11 PM
FTNW's Avatar
wouldnt what ?
im trying to take off the two layers of paint on my car for primer before i send it to a shop for paint
Old Dec 16, 2010 | 08:48 PM
DC2.2_GSR's Avatar
Originally Posted by FTNW
wouldnt what ?
Why? Is the paint damaged? Unless the current coating is failing or unless you know for a fact that the previous job was done horribly then just leave it alone and prep it normally. The only other reason to strip all of the paint off of a surface is because it has a ton of corrosion (rust), if it requires a ton of body work or if you're doing a high end show finish that you want to start fresh with.
Have the shop do it since they have the proper tools and experience. If you're trying to save money by doing it yourself, you're going about it all wrong. A DA sander costs anywhere from $100-200. You'll go through a shitload of 6" sandpaper on the DA removing the paint and even if you're just prepping normally you can expect to use quite a bit. That's from $40-ish (if you just prep the surface normally) to $100+ if you try to mechanically strip it just on sandpaper because you can never just buy a few sheets... any different grits you need you'll have to buy a whole box.
Unless you already have the equipment and the materials or unless you're genuinely interested in tackling the project yourself and are willing to spend a good chunk of momney to get started and do it right it's far better to just let the shop do their thing.
ITR9788
Mar 10, 2006 07:26 PM
oldskooljdm
Dec 16, 2003 07:24 AM
crewjones
Jun 23, 2001 07:48 PM
