Rear disc swap / trailing arm bushing
I purchased a rear swap some time ago and finally got around to installing it into my 96 EX coupe. The trailing arm bushings are pretty beat up, almost to the point to where I can break the rubber out by hand.
I found the tutorial on swapping the bushing but am considering using black silicon glue (like the kind used for replacing windshieds) to strengten the bushing back up.
I've read that some people do this to their engine mounts vs. buying new solid mounts or inserts.
Has anyone done this and do you think it's a viable alternative to replacing the stock bushings?
I plan on having the rear end compressed to close to ride height before I apply the glue and will likely not completely fill the voids but maybe up to 60-75%.
Any sound advice/opinions is appreciated.
A few links for this process being done on motor mounts.
http://importnut.net/motormount.htm
http://rav4world.com/forums/viewtopic.php?t=15139
If there's not much input, I'm gonna try it over the holiday break.
This is a vital part of your suspension, I’m sure it could be done and probably last years, but then a lot of the stress will be put on your other bushings. Those bushings are designed to flex and with window glue it will not flex. If you’re looking for a harder bushing then oem, look into hard race, I’ve heard nothing but good things from people who have used them.
ok dont do it yourself cause you dont have too take it to a dealership they have replace it for free!!!! i said free!!! its a factory recall they replace it with one thats mugen!
ok but heres the catch any dealership will try to f**k u because they wont make any money remember its a recall its replaced free this a win win deal cause your getting the best parts with labor free and if they try to charge u or say no with some kind of warranty bullshit that your suspension has been modded and its void lol this is what u do get them to print u out the reason that they will not do the work on a dealership letter head (not a plain sheet of paper its has to be from there)the signature of the person that told u and a witiness. than go see a lawyer (lawsuit are usually probono) u have right under the constition amd sema (i have any case files for the lawyer just in case they stupid too . you will not even have go to court they will have to settle (then u can go to that dealership with there money and grab u crz or something
I put Energy Suspension polyurethane bushings in my 95 and they've been working good. The car rolled like crazy on the worn out stock bushings but now handles good. They're definitely stiffer than stock too and not very expensive (less than OEM replacements)
Reasons, 1, you have no proof. 2, Why in the hell would honda use MUGEN bushings?
3, I have never ever heard of anything such as this, and my friend's dad has been working at honda for over 15 years, and he has never once heard of this.
Untill I see some proof, you are full of ****.
ok the ceo of honda is the owner of mugen (thats why they would use mugen) both the oem and mugen are stamped with the same part number and say honda on them!!
the recall is in the dealership computer (recall means faulty part so manufactor has to replace so they do not get sued) like toyotas (they had a recall on all their cars cause they where killing hundreds of people)
i took a dealership to court myself without a lawyer filed all paperwork at courthouse cause they said my intake voided my warranty .
sema and congress has laws to protect us from warranty fraud - no aftermarket parts will void warranty unless youve unbolted the valve cover and messed with the interenals and still they would have to prove u did
you can get proof (use your computer) faulty P/N 52385-SR3-000 defect code 042
Caoboy
41
Jan 20, 2015 09:59 AM
DerangedEG
Jan 13, 2004 07:02 AM
