compression result on b18a1 crx
well i did a compression test on my motor... cylinder 1,3 is little off on dry shot and wet..
2,4 is near to perfect compression..
this was done .. cylinder 1=175 2=185 3= went to 180 then second and third try 175, 4= 185...
so any clues?? i did find little bits of oil on my spark plugs on the bad cylinders ( 1,3)
i also heard small pop and seen air leaking out when i was testing those chambers
anyone got anything to say??/
as far as i was told motor should be around 100k miles by now...
doesnt burn oil. if so very little
as far as i know my valve cover seal is bad
well also.. i found oil deposits on my spark plugs and when i did test cylinder 3, 4 their was air escaping... i heard a pop during the testings... and then i seen puff of air
doublezerohatch
Jul 1, 2013 08:03 AM
GSX TO CX
22
Feb 3, 2005 08:10 PM
