What standard AFR tuning for honda
Old Dec 8, 2010 | 09:58 AM
majdi's Avatar
Default What standard AFR tuning for honda
Hi, i just found and reading about afr tuning, but i not sure it standard for all car or not.
here the url : http://www.buckeyetriumphs.org/techn.../AFMonitor.htm
Old Dec 8, 2010 | 01:08 PM
GhostAccord's Avatar
Default Re: What standard AFR tuning for honda
Each engine setup could be a little different. In order to see exactly where your engine performs at it's best. You would have to put your car on a dyno or tune it at a track where you will see the quantitative performance/economy changes as you change the fuel & timing maps. Timing has a lot to do with performance and economy as well.
Just tuning your car to read 12.5 or 15.3 AFR doesn't necessarily mean you are getting the most out of your setup.
Old Dec 9, 2010 | 07:13 AM
majdi's Avatar
Thank G.Accord for explanation, so it mean wideband just a reference to us tune our engine, depend engine need.. 12.3 setup not the maximum power if our engine not fit with the setup rite? Please correct me if what i doing is wrong step to tune p30 h22a engine.
1. Load P30 H22a bin to ecu. + remove checksum + crome rtp plugin
(Vtec set at 6000rpm to tune low load)
2. Test run and datalogging with freelog 1.0.93
3. After get the logged a/f. i divide with target a/f. eg: ((Logged a/f) / (Target a/f)*Current basemap) (17/14.70)*20 = new map value at logged point =23.
4. I edit all logged a/f with freelog to get new map value.
5.Doing the same but vtec set to 4800rpm to tune high load.
i feel little change, after vtec kick it pull hard more then before i tune.. is there any step i miss in tuning h22a engine?
raverx3m
Aug 28, 2012 05:24 PM
ScubaStevo80
Feb 9, 2006 10:26 AM
EFIGUY
Jan 26, 2005 04:14 PM
SCYRIO
Dec 13, 2004 07:08 AM
pacifico
Aug 14, 2004 01:46 PM
