START UP ISSUES>>>
Old Dec 7, 2010 | 07:02 PM
soLaLive's Avatar
Default START UP ISSUES>>>
OK heres my problem .. my 90 honda accord has been sitting for a while.. but every now and then i crank and it starts fine. but after a week of not starting up the car i went back to crank it. It crank but wont turn over. i did it a few time and still the same. I try the startup fluid and still wont work. i thought it was the battery so i charged it. then after its been charged i try to crank it again. all power will come on but when i crank it and turn it back off, everything dies. no sign of power or what not. can it be the battery?? distributor? ecu? let me know if you know whats wrong with it. THANKS GUYS.
Old Dec 7, 2010 | 07:33 PM
AndyD's Avatar
Default Re: START UP ISSUES>>>
Check your ground wire. Make sure it is secure to the chassis and corrosion free.
Old Dec 8, 2010 | 03:13 PM
soLaLive's Avatar
its corrosion free but it used to start so i dont think it can be the ground wire. but i can also check that. thanks for the feedback.
ProfMore
Oct 11, 2017 06:29 PM
Hatchback_Pat
Aug 25, 2014 04:53 PM
ramswood2000
10
Sep 27, 2010 05:20 AM
rick_rabies
26
Apr 5, 2009 01:07 PM
