91 civic dx HELP!!
i have a 1991 honda civic dx d15b2 dpfi.. it starts, runs, and idles fine! when i take off in gear and step on the throttle the car bogs and sputters! it only does it at about 3.5 to 4k rpms?!?! i replaced my fuel injectors because i had code 16 on the ecu and after i installed them the code still blinks 16 times?! do i need to reset the ecu? i also replaced the fuel pump, fuel filter, spark plugs, timing belt, water pump, both injectos, cleaned the iacv, and fresh oil change and oil filter. i also replaced the cat with a straight pipe. i replaced all these parts within the last week and still didnt solve my problem! any help appreciated
the car drives fine when i stay under 4k rpms. its when i step on it that it bogs and sputters but the car still stays running. it doesnt ever die. the timing is good and i got spark on all the plugs. any other suggestions. still havent solved my problem.....
phaphon
11
May 11, 2010 09:41 AM
HiyahBeech!
Oct 12, 2007 02:53 AM
