Fuel consumption, help!!!
i have 98 lx civic, totally stock, auto tranny slipping on 2nd gear, i drive like an old woman, keeping my RPM below 3k, i changed my fuel filter, oil 40/10, oil filter, air filter, cleaned my injectors and still i get 180MILES PER FULL TANK!!!!!!!! WTF?!!!!
i check my O2 sensor its working fine, i use 90 octane fuel, i have 15" ULTRALITE Atec rims, what more info should i include?!
whats going wrong?! please help, a normal civic should get at least 300MILES per full tank
Re: Fuel consumption, help!!!
no, actually i dont know how to do that, what color on my spark plugs should i see if it was rich?! and if it was, what is the solution?! about timing issue, how can i know if its still factory tune?!
to check the timing you going to need a timing gun, and i believe the specs on that d16y7 are 16 degrees some1 correct me if am wrong.
here is a link to check the plugs:
http://www.theultralightplace.com/sparkplugs.htm
ma bad i take that back its supposed to be at 12 degrees, well when i had my 00 hatch no mods, driven carefully i was getting more than 300 miles to the tank. if your car is well mantained i would say at least 29 city 33 highway.
You should be getting at least 300 to a tank (10.9 gal tank, approx. 30 mpg) im out of ideas if its not plugs/wires or timing. Any weird sounds or strong gas smell when driving?
how can i know that my d16y7 is 12 degrees on timing?! i'm changing my rotor and cap on Saturday and i wanna make sure that the dizzy is placed right, i just changed my timing belt too and spark plugs wires and advanced my dizzy a bit.
