No brake lights, Need help ASAP (Searched)
Old Dec 4, 2010 | 04:39 PM
misha's Avatar
Default No brake lights, Need help ASAP (Searched)
No brake lights come on.
Everything works normal. My lights are on when i turn them on, but when i hit the brake pedal nothing happens.
I checked brake light switch with a multimeter and its fine.
Tried jumping the connector wire of a brake light switch and the brake light did not come on.
Put new bulbs in, fuses are good.
Im stuck at a friends house and have to leave home asap. Please help!
Thanks
Old Dec 4, 2010 | 05:36 PM
misha's Avatar
Default Re: No brake lights, Need help ASAP (Searched)
horn works, under the dash/under the hood fuses are good
im really stuck, please help
Old Dec 4, 2010 | 06:03 PM
KINGVEM^^ED6's Avatar
i was gonna say horn fuse
Old Dec 4, 2010 | 06:05 PM
walkenman's Avatar
run yourself a wire from the brake light switch back to the taillights untell you can find the problem
Old Dec 4, 2010 | 08:30 PM
Laserjock's Avatar
Use the voltmeter to check for voltage at the connectors in the rear hatch.
Clean contacts of the bulb socket
You mean the marker lights are on but no brake lights? I'd use the direct wire to the battery idea to make sure no wires are cut in the body harnes
Old Dec 5, 2010 | 04:59 AM
misha's Avatar
Its a sedan.
Whne i turn my lights on, headlights, corners, rear lights go on like ususal. When i hit the pedal brake lights DONT get and brighter.
So your saying mybe there is a cut somewhere between the brake light switch and the bulb? Because its the same bulb that goes on with the lights on and gets brighter when you brake, right.
Old Dec 5, 2010 | 10:11 AM
LudeEFv2.4's Avatar
My old title sucked.
Sounds like a ground issue. I'd start with the trunk area.
Old Dec 5, 2010 | 06:15 PM
96Formula6spd's Avatar
Had the same problem in my crx. Almost got hit a few times. I took a new wire and stuck it in the fuse box for the brake lights. Then cut the power wire for the brake light switch and tied them together. Worked since. Traced the wire in mine and it was fine everywhere. Old honda wiring ftl.
JDM_rolex
Mar 15, 2025 04:50 PM
TomCurllyFry
Mar 25, 2013 09:29 PM
decode33
Honda CR-V & Element
Feb 25, 2011 10:49 PM
erikwithak
10
Aug 9, 2009 02:39 PM
Ragged91ZC
11
Mar 12, 2004 01:01 PM
