BRAKE LIGHTS
Re: BRAKE LIGHTS
possibly your brake switch which is located at your brake pedal linkage.
check to see if you have power on one wire, and when you apply the brakes, that you have power going through to the other wire.
Re: BRAKE LIGHTS
ok so went outside the switch isnt stuck it comes out when i push the pedal in. i have tail lights and i have license plate lights so the fuses are good what else could cause this
SOMEONE PLEASE
ive looked on other threads and well ive checked all those things
please please please please please please please
SOMEONE PLEASE
Re: BRAKE LIGHTS
What year?
You can't necessarily tell whether the switch is bad by looking at it. If you unplug the switch connector and jump the connector with a wire, do the brakes now turn on? Does the brake light fuse under the hood have battery voltage? Is the black brake light ground wire in the rear broken?
Re: BRAKE LIGHTS
Yes, jump the brake switch connector and then look for whether the brake lights turn on. If so, check the connector for damage or replace the switch. A cheap test light would also work.
misha
12-05-2010 06:15 PM
JDM_rolex
06-06-2009 09:17 AM
