rattle noise
Old Dec 3, 2010 | 05:18 PM
2kdrift's Avatar
Default rattle noise
my car started making this really bad rattling noise. it is only under acceration. and if i take the car out of gear the noise will also go away. more noticeable under load. uphill its very loud downhill u can barely hear it.
thanks guys
Old Dec 3, 2010 | 05:35 PM
Rylan's Avatar
Default Re: rattle noise
Where is the sound coming from though?
Old Dec 3, 2010 | 06:06 PM
2kdrift's Avatar
from the frot somewhere. i am guessing its my input shaft bearing or my throw out bearing. even though they are both relatively new they are not honda oem bearings.
Old Dec 3, 2010 | 06:12 PM
VietBloodXIII's Avatar
If it's only making noise when you're in gear then it's probably something with your transmission. Try revving your engine while you're still rolling to make sure.
Old Dec 3, 2010 | 06:14 PM
Former User's Avatar
Also check the exhaust heat shields. They may be loose or cracked.
Old Dec 3, 2010 | 06:15 PM
And I meant rev it in neutral while you're rolling.
Old Dec 3, 2010 | 06:46 PM
Markley02's Avatar
There is also the bearing between the main shaft and the case. (Other side than the input shaft bearing) That one went bad before the input shaft bearing on my b16 tranny.
Old Dec 3, 2010 | 09:14 PM
drgtr's Avatar
Could it be the car is pinging? Bad knock sensor?
Trevo Badri
Transmission & Drivetrain
Apr 4, 2019 12:44 PM
1clean01
Honda Civic (2001 - 2005)
May 2, 2012 08:11 PM
EKBEAMIN
Feb 11, 2012 08:35 AM
ludesrv
Aug 30, 2008 09:36 AM
onyx00
Dec 12, 2005 09:56 AM
