98 Civic EX - Automatic Transmission Shift Problems & CEL
Old Dec 2, 2010 | 02:02 PM
js648's Avatar
Icon2 98 Civic EX - Automatic Transmission Shift Problems & CEL
Hello everyone, I have a simple question: What would cause my ECU to signal an error code 7 (TP Sensor), 13 (Baro Sensor), and 61 (Primary Oxygen Sensor) all at the same time? I pulled the 7.5 amp backup fuse under the hood, reinserted it, and the car drove significantly better. Not stalling when putting the car in park, reverse, or at low RPMS like it was before. Although, my car is still having problems shifting gears. It's revs up to 4000+ RPMs before it wants to shift up to the next gear.
Any advice or recommendations would be appreciated. Thank you for your time.
Old Dec 2, 2010 | 02:09 PM
Former User's Avatar
Default Re: 98 Civic EX - Automatic Transmission Shift Problems & CEL
Did all three codes return after resetting the ECU? Did only the TPS code 7 return? The ECU relies on signals from the TPS to know when to tell the transmission to shift gears.
Old Dec 2, 2010 | 03:14 PM
js648's Avatar
Yes, they all returned within minutes of resetting the ECU. Thank you for your quick response.
Old Dec 2, 2010 | 03:54 PM
Did you do some work on the car recently? What is linked to the codes being thrown?
Old Dec 2, 2010 | 06:04 PM
js648's Avatar
I didn't get a chance to pull the codes from a computer. I simply used the jumper method by taking the passenger kick panel out. I'll try to go to auto zone tomorrow to pull the codes. I haven't done any work besides changing the spark plugs and wires. I changed the plugs in response to the hesitation of the transmission just to make sure it wasn't any of the spark plugs.
Also, another symptom I've been experiencing is that I can't shift into gear from park to reverse. I hear a clicking noise coming from underneath the shifter.
Old Dec 4, 2010 | 03:32 PM
jjmajed's Avatar
DELETE
rkthunder13
Jun 7, 2019 12:29 PM
TC21
Jul 23, 2007 10:30 PM
bogus_ek
Aug 22, 2006 01:31 PM
Deviation
11
Apr 29, 2006 05:31 PM
Lowez
May 30, 2002 07:06 PM
