Super Idle Problem, Help!
(IACV Damaged [Oscillating], FITV Eliminated, IAT New, new spark plugs, new spark plug wires)
Well the story begins when coming to my house today I'm on the normal way, when I reach a stop the car listening a "Plak" and begins to oscillate, the car starts to oscillate (cuz damaged IACV) as well but super fast from 1200rpm to 1400rpm and then I was like "what has happened here?" ... the car stopped making the classic Oscillating IACV and started to do that ...
when I accelerate in first gear while I'm getting the clutch and speeding to exit ... revolutions begin to swing higher ranking between 1100 and 1500rpm and when the car goes out, the car starts to kick...
please help !?... : (
here a video of exactly what happens to me but the difference is that mine does not go out ...
http://www.youtube.com/watch?v=rebkNJMAu0k
Re: Super Idle Problem, Help!
i had a problem with my b16a2 but my idle wasnt that fast it was flucuating between 1000-2000 there was a leak inside my THROTTLE BODY where the 2 holes are, the top was leaking for me so i tapped it up to plug the leak. hope this helps.
anyone else please...
CEL on
First ECU Reset:
- #14 IACV
- #41 primary oxygen sensor heater
Second ECU Reset:
- #14 IACV
i will do tomorow a last ECU Reset to be sure!...
any opinion is welcome!...
respect!
First ECU Reset:
- #14 IACV
Second ECU Reset:
- #14 IACV
respect!
IACV which stands for Idle Air Control Valve...
That would probably be the idling issue if its throwing Code 14, take it off and clean it all out well, and reinstall.
yep sometimes cleaning ur IACV doesn't do anything. the plunger on the inside is probably damaged. get a new one. also get another o2 sensor or fix that code too.
this means that works or it can be damaged anyway?...
respect!
Make sure the IACV connector plug is right. People when pulling em off end up pulling the plug apart and pin it wrong. Can you take a pic of how you eliminated the fitv. I was having the same problems in the same car as your sig with my ls swap. My fitv plunger backed out and helped with bad idle. Bypassed my fitv also.
Third ECU Reset:
- #14 IACV
oK i think i will buy a new one...
i will buy:
- new IAC
- new FITV
- new O2 sensor
respect all!
any other opinions is welcome!...
- #14 IACV
i will buy:
- new IAC
- new FITV
- new O2 sensor
respect all!
respect!...
Hmm wouldn't be adding to your idle problems? The coolant is what causing the fitv to open up and operate. So if you plugged the vac holes the coolant is still causing the fitv to work so it's not bypassed. Someone correct me if I'm wrong.
if u eliminate the air holes he cant move the rpm cuz he doesnt have his air holes...
then if u eliminate the coolant hole of the FITV, the coolant cant pass to the IACV... then ur IACV cant be refreshed by the coolant... cuz u eliminated the pass of the coolant of the FITV...
i hope this help u... my english is a lil bad i think so hahaha...
respect!
i think is bad cuz the IACV get HOT coolant... with the FITV, it ride more and when the coolant reach IACV is a lil fresh...
good luck bro!...
Yes, even though u put power to the IACV and it clicks, it can STILL be damaged. The plunger may not close all the way. it can stick open. i bought another IACV locally for $10. good luck. post when u have fixed ur problems!
i will buy it from www.hondapartsnow.com... is more cheap for me here...
or is another please?...
respect!
GSR4U2NV
05-25-2006 07:30 PM
