95 del sol/d16z6 motor chipped p28 - Misfire problem
Old Dec 1, 2010 | 09:18 PM
2kdrift's Avatar
Default 95 del sol/d16z6 motor chipped p28 - Misfire problem
95 del sol d16z6 motor
chipped p28
okay my car was running fine until the other night all the sudden it started missing at high rpms especially at WOT.
* car starts perfectly
* car idles perfectly
* can rev to redline in neutral no problem
when driving i do get some minor missfires at low rpm. at about 3 or 4k if i am at WOT it will stop revving and missfire like crazzy. if my foot is not so heavy i can raise it pretty high through the rpm band with no missfire.
REPLACED-
distributor
spark plugs
spark plug wires
thanks in advance. for any info / ideas. like i say it was running perfectly a few days ago
Old Dec 1, 2010 | 09:26 PM
highliner82's Avatar
Default Re: Missfire problem
chipped p28
REPLACED-
distributor
spark plugs
spark plug wires
kailua huh i used to live in kaneohe! anyway hows ur timing?and any cel?
Old Dec 1, 2010 | 09:35 PM
2kdrift's Avatar
no cel. i assume my timing is still good. i need to double check that with a light though. i did look at my ditributor bolts and it had not moved, and when changing it i set the new one right in the middle where it should be.
Old Dec 2, 2010 | 03:02 PM
2kdrift's Avatar
bump - i think its my fuel pump i will replace it tonight with a stock one and also check timing. i have a really bad feeling when i purchased my walbro from ebay i got a knock off >.<
OldManTSX
Mar 15, 2016 12:00 AM
rewerbcrx
Mar 20, 2008 11:00 PM
delsoldriva
Mar 7, 2008 03:38 PM
polsky's del sol
Jan 1, 2008 10:33 PM
DeadVet
Oct 25, 2004 11:35 AM
