H22 into 95 dx coupe
Old Dec 1, 2010 | 02:16 PM
Civic2bBuilt's Avatar
Default H22 into 95 dx coupe
I just picked up this civic last night in a trade. Today was the first chance I got to actually pay attention to it when driving it.
Body is a 95 DX EG Coupe.
Swap is from a 2000 Prelude (H22a4)
p28 ecu chipped
I have rode in many different h22 swapped cars and this one does not seem to be anything near what those were. But here are my current issues...
1. Vtec = No engage
2. Temp gauge = It works, but if the sensor Im looking at is the correct one, it is not plugged in at all.
4. Throttle cable/bracket
So my questions are:
What do I look for to see if the Vtec is correctly hooked up. I understand that three wires need to be ran. Does anyone have a diagram for this?
Which sensor is the temp sensor?
What throttle cable and bracket are needed for this swap? The one on this is rigged up just a bit so I would like to fix that.
Sorry if these are questions that are asked a lot. I am new to the H22 deal. I usually stick to the easier swaps. lol
I tried doing a search but I am on my phone which does not do that very easily.
Thanks for the help.
Old Dec 1, 2010 | 02:29 PM
Former User's Avatar
Default Re: H22 into 95 dx coupe
For Civics, the temp sending unit is generally a 1-wire sensor under the distributor. It may be the same for your H22.
Old Dec 1, 2010 | 02:35 PM
Okay. I will go outside and check it out tomorrow.
Its about 20 degrees and its snowing... All I have is a car port for the time being. lol
Oh the hell with it. Im bad with anticipation.
Going outside now.
Old Dec 1, 2010 | 02:38 PM
It's definitely not the best time of year to work on the car, depending on where you live. In Houston, it's fine (60F today). Here, it's the summers (95F/95% humidity) when car work is a challenge.
Old Dec 1, 2010 | 02:54 PM
Alright I took a bunch of pictures and I will put them on here in a few.
The sensor that your speak of, is indeed plugged in. But the one that I found unplugged, is where the upper radiator hose connects to the engine... I will show in pic. Give me about 20 minutes so I can get on the computer.
Old Dec 1, 2010 | 03:08 PM
Okay so when I picked up the car the guy I got it from said that there was another "chip" in the ash tray.
So I took the p28 apart and plugged in the other one. It seems to run much better now. But still not what I expected.
The vtec is wired up, just need a diagram to make sure it is wired correctly.
Old Dec 1, 2010 | 03:19 PM
#1 This is one sensor that has no plug going to it... What is this?
#2 Here is the other sensor that has no plug. Note- The rigged up throttle cable.
here are some pics of some vaccum hoses that are either plugged or go to nothing. Would like them to all be used correctly.
#3 Back of intake manifold by the throttle body.
#4 Behind fuel rail.
#5 Hard to see but this is on the back of the intake mani on the drivers side.
Took some pics of the Vtec wiring as well. Note- Colors do not match but If I know where they go to on the ecu I can make sure they are correct.
Old Dec 2, 2010 | 03:59 AM
bump
mikegeezy
Apr 2, 2006 10:08 AM
syndicatemotorsports
Jan 22, 2006 07:47 AM
nurvcom..
Northern California (Sales)
Oct 2, 2005 06:35 PM
Eq_Coupe2k
Jul 18, 2005 07:00 AM
cfinch
24
Jun 17, 2002 01:31 PM
