Turn signals not working but hazards do??
Old Dec 1, 2010 | 11:48 AM
efcivic317's Avatar
Default Turn signals not working but hazards do??
EDIT: Found the problem, bad flasher/turn signal relay. mods can delete or lock this
Old Dec 1, 2010 | 12:24 PM
ED94LIFE's Avatar
Default Re: Turn signals not working but hazards do??
I had a Lumina with the same problem and it was the signal lever on the steering column.... if that helps at all or it could possibly be the turn signal flasher.
Old Dec 1, 2010 | 12:44 PM
FSRslug's Avatar
Download the manual from honda hookup. It has everything to troubleshoot the turn signal/hazard circuit.
Old Dec 1, 2010 | 03:20 PM
efcivic317's Avatar
I found a fuse on my floorboard would this have to only do with my singals?
Old Dec 1, 2010 | 04:41 PM
DTK-Racing's Avatar
check the fuse
Old Dec 1, 2010 | 07:36 PM
FSRslug's Avatar
It could be the problem. It will be a 10A fuse.
Old Dec 2, 2010 | 01:48 PM
end005's Avatar
where is this relay at? I'm curious if this is what's wrong with my car.. (left signal doesn't work when I step on brakes)
Old Dec 2, 2010 | 02:25 PM
efcivic317's Avatar
its in the fuse box under your dash on the top left its a black box looking thing, they are like 10 dollars..
fredefhatch
Aug 1, 2012 07:09 AM
tallguy21
May 17, 2012 04:13 PM
gnxpro24
Feb 2, 2011 03:52 PM
CeReal
Jan 26, 2008 09:55 AM
RapeV-8
Apr 15, 2003 10:26 PM
