antifreeze question/ civic eg hb
Old Nov 29, 2010 | 10:08 PM
qpzm12's Avatar
Icon2 antifreeze question/ civic eg hb
is it bad to mix coolant and water? it says not to on the can of antifreeze, but there was a bit of water in the radiator.
Old Nov 29, 2010 | 11:02 PM
NotAJDMFanBoy's Avatar
Default Re: antifreeze question/ civic eg hb
Is it premixed stuff in a bottle, the 50:50 stuff to top off with? Don't dilute further. If the motor was full of just water, drain it and add plain antifreeze (there will be a lot of it left in the motor). If you're just a little low and it's the regular 50:50 mix, it's fine to top off.
Old Nov 29, 2010 | 11:07 PM
s13hero's Avatar
It will just throw off your mixture of propylene glycol to water ratio. You can test your level of protection with a coolant tester kit
Old Nov 29, 2010 | 11:11 PM
collin-eg2's Avatar
Or you can drain your radiator from the drain plug at bottom and drain your block from the coolant jacket drain plug. Add brand new Honda/Acura pre-mixed coolant
Old Nov 30, 2010 | 07:01 AM
300whpej's Avatar
plain and simple, your motor will not be negatively affected by a 48/52 mixture. 50/50 is best, but thats almost never reached perfectly.
Old Nov 30, 2010 | 07:09 AM
Former User's Avatar
Only dilute antifreeze with distilled water. Tap water has corrosive minerals.
GoLowDrew
19
Jun 13, 2005 09:01 PM
SpoonIntegra808
Oct 21, 2004 05:04 AM
99bb6
10
Sep 23, 2004 08:36 PM
fc3sol
May 4, 2004 10:24 PM
onyx00
Dec 14, 2003 11:44 AM
