LSD off center?
I just put an OBX lsd in my b16 trans and noticed a strange problem. As the top half of the case was off, I spun the lsd to make sure the gears were working and noticed that it looks as if the lsd is a little off center when spinning. (Maybe about 1/16 of an inch). The bearings were pressed in all the way and everything else went smooth. Its hard to explain but is similar to if the wheel on your car was not perfectly centered on the hub.Is this something to be concerned about? Thanks
I have not heard of this issue with the obx. But I have heard the other million complaints. I just got a good deal on it and figured I would give it a try. Any links to other ppl with the same issue?
lovey408
21
Sep 6, 2007 07:35 PM
