Transmission & Drivetrain Gearboxes, Differentials, Clutches
b16a transmission whines
Old Nov 29, 2010 | 05:05 PM
Tegarator's Avatar
Default b16a transmission whines
i have a 91 acura integra with a b16a cable tranny. i just replaced the pass trans seal, (input shaft seal) it set at a angle couples days had to find the seal. i got it all back together now when i engage the clutch and put it in gear it whines. it does not matter what gear. what i can hear it only does it in idle, if i drive it quite but if it just in idle with the clutch in gear it whines sounds awful. can someone help im so lost, thanks
Old Dec 11, 2010 | 10:09 PM
Gearspeed-Performance's Avatar
Default Re: b16a transmission whines
Given you had to replace and axle seal..it was probably leaking..so there is a chance you ran it low on fluid which is not a good thing. You may have a bad differential or input shaft bearing. They whine when they are on their way out. Did you check fluid level and condition?
Old Dec 13, 2010 | 02:43 PM
Tegarator's Avatar
When i replaced the seal itself it leaked fluid. so i put about a quart and half in it not really sure how to check to fluid on a straight shift. My buddy told me to stick my finger in the hole you fill it in to make sure u can feel then it is full. so i went off of that so i replaced the oil in bout a quart and half low.
Old Dec 14, 2010 | 06:36 PM
Right next to the axle output there will be a fill bolt that your buddy is talking about..you stick your finger in there to check the level. A quart and a half low is a lot to be low by and not sure if you leaked all that out replacing the seal...it may have been low for a while and may have ruined one or more bearings.
Old Dec 18, 2010 | 05:05 AM
Tegarator's Avatar
Alright well thanks for the help man
RunninEg6
25
May 11, 2009 03:40 PM
turbotime
May 27, 2006 02:27 PM
01_S2k_Driver
Feb 7, 2005 04:23 AM
Jer'rome
Jul 5, 2004 08:35 PM
Toretto
May 12, 2003 01:02 PM
