3/8" vs 1/2" turbo flange
Old Nov 29, 2010 | 04:44 PM
SiR99's Avatar
Default 3/8" vs 1/2" turbo flange
Hey guys I searched but found answers that contradicted each other. Will I be okay if I use 3/8" flanges for my T3 turbo manifold, 4 bolt dp and wastegate? Found some people saying that 3/8 should be fine and others saying 1/2, so I wanted to get more opinions.
Thanks
Old Nov 29, 2010 | 07:12 PM
turbojeesx's Avatar
Default Re: 3/8" vs 1/2" turbo flange
3/8" is fine. 1/2" warps slightly if not bolted down to anything so there really is not too much of a benefit to me personally. If you do not have any extra flanges/drilled out thick aluminum, then just bolt the flange down to your exhaust housing while welding and there will be no warpage.
Old Nov 30, 2010 | 05:06 PM
pauld's Avatar
I used 3/8" flanges from weirtech to build my manifold, and they have held up just fine. I did end up having to get the faces machined flat after I welded it up, which was my own error, not the flange thickness.
Old Dec 3, 2010 | 07:25 PM
SiR99's Avatar
Thanks for the replies
BoostFlow.com
Nov 2, 2011 10:00 PM
SOHCD16y8
Jun 10, 2005 08:04 PM
2FASTDC2
Feb 4, 2004 06:11 PM
94lsboost
Dec 18, 2003 10:37 AM
Tru Dynamix
Oct 4, 2002 08:58 PM
