D16Y8 Knocking Sound
Old Nov 29, 2010 | 03:23 PM
TekSI's Avatar
Default D16Y8 Knocking Sound
My wife was driving home today, and heard a knocking sound from the car(97 Civic Ex, auto, 130-140k miles) at startup, and shut the engine off and started again when she got home, and heard more knocking. The car had oil slightly above the low point, filled to the high with no difference.
I read that the Y8 has issues with spun bearings. Would a spun bearing or other engine knock source cause a check engine light via the knock sensor? I really hope it's a simple issue, but is almost certainly coming from the head or block.
Thanks in advance
Old Nov 29, 2010 | 04:17 PM
habib's Avatar
Default Re: D16Y8 Knocking Sound
When you pulled out the dipstick did you see any metal shavings?
Old Nov 29, 2010 | 05:52 PM
TekSI's Avatar
None at all, there was nothing out of the ordinary.
I just checked again, and there is some vibration in the engine as well. Would it be possible for the timing belt to skip a tooth on the sprocket and cause this problem? I'm just trying to think of other ideas...
Old Nov 29, 2010 | 06:04 PM
Former User's Avatar
Use an engine stethoscope or something similar to pinpoint the source of the noise. Is it coming from the head, block, or drive/timing belt area?
Old Nov 29, 2010 | 06:39 PM
TekSI's Avatar
Update:
I used a screwdriver as a stethoscope, found lots noise from the block and belt areas. I looked at the dipstick again, and there are tiny metal shavings in the oil. I'm gonna tell her not to drive it for now, as I don't trust it.
Old Nov 29, 2010 | 06:47 PM
habib's Avatar
You have a spun bearing
Old Nov 29, 2010 | 06:50 PM
robbyzune57's Avatar
Originally Posted by TekSI
Update:
yea if there is any knocking sound its usally bad news if there is slight tapping from the top of the motor it is just lifters but if its knocking hard it could be a rod or valve i would get it checked out asap
Old Nov 29, 2010 | 10:09 PM
h22accord101's Avatar
i wouldnt start the car up any eaither take the oil pan off and check bearings you may just get away with replaceing the rod and main bearings and not have to turn or get a new crank thats if it hasnt messed it up yet
Old Nov 30, 2010 | 12:36 AM
-__-'s Avatar
yeah take care of it NOW. do not start the motor. rod knock is not good and scary lol.
Old Nov 30, 2010 | 08:44 AM
TekSI's Avatar
I appreciate all the quick responses. As a rod bearing is gone (at least one), the fuel tank leaks (can only hold 1/2 tank without emitting strong vapors), a/c compressor is dead, trunk leaks, etc., we're going to replace it. I don't think it's worth all that work for a car this old that she wants gone anyway.
Old Nov 30, 2010 | 10:29 AM
strategy400's Avatar
In that case take it off roading (get some shots of it airborne).
Old Nov 30, 2010 | 02:37 PM
JDM8o9's Avatar
if you dont sell the car, part it out ..the catlytic converter is worth money
Old Nov 30, 2010 | 03:29 PM
TekSI's Avatar
The car has an old set (2004 maybe) of Tein Basics, so offroad may not be fun for anyone in the car. May try to trade in, if not I'm not sure, probably will part it out.
I have the WRX for offroad anyway.
Old Feb 21, 2011 | 08:45 PM
Dudeman289's Avatar
looking for anyone that can help me...my d16y8 is making a strange noise which seems to be coming from the tranny, kind of a rattling only when its cold....heres a vid of it http://www.youtube.com/watch?v=UAWfGiLqWrw could it possibly be the throwout bearing or bad pressure plate?
Dudeman289's Avatar
thanks in advance for any and all help
CodeBlue
Honda Civic (2006 - 2015)
11
Feb 3, 2010 09:25 PM
farhan445
Nov 21, 2006 07:03 PM
stewdabaker
Feb 24, 2006 03:15 PM
96Spec Ek
Dec 23, 2005 12:17 PM
alopez84
Mar 28, 2003 01:11 PM
