Here's how I fixed my rear disc problem...
Where the bolt and pin where they were frozen together with rust and nasty grime. I couldn't find anything like that at the hardware store so I decided to make them even better by just using a ss nut and bolt and some washers to make sure it would clear everything. So what I did was dremel out the spaces between the fork and the bracket on the caliper until they came apart then drilled out the center. Then after that all I did was put a screw covered in Lithium Grease between them and here's how it looks now...
Mmmmm new Calipers to...
FourthGenHatch
14
Nov 19, 2007 10:30 AM
VTAC-KAT
11
Nov 2, 2006 03:19 PM
