99 Ek civic 1.4 - Will my current tranny work with a B16 engine swap?
Old Nov 29, 2010 | 12:53 PM
project.stance's Avatar
Default 99 Ek civic 1.4 - Will my current tranny work with a B16 engine swap?
i have a 1.4 99 ek and would like to put the b16 into it, just wanted to know if my gearbox will fit straight on? also all bits and bobs? basically i need someone who has done the same swap to tell me what to do! any help appreciated
Old Nov 29, 2010 | 02:34 PM
EJ Eire's Avatar
Default Re: 99 Ek civic 1.4 - Will my current tranny work with a B16 engine swap?
No it won't bud and even if it did the ratios would be ****...there bad enough beyond 3rd in the 1.4 as it is. At least as far as I know that's the case
Old Nov 29, 2010 | 03:28 PM
so i'll need need the gearbox, but i'll be able to use the same loom etc? sorry i don't know a lot about engines etc, just need to know what to buy!
Old Nov 29, 2010 | 03:38 PM
4wd eg6's Avatar
u need any b-series tranny b18, b16, gsr or type r, etc. any tranny from a b-series engine, for a ek u need a 94-01 integra tranny or 99-00 civic si only.
Old Nov 30, 2010 | 03:01 AM
EJ Eire's Avatar
Sorry missed the second part of the question...The ECU will need to be changed as it's there's not vtec to start with in a 1.4 but as well as that mounts, the loom if you want to make it easier etc.
Here's a link gives a good overview of each
Old Nov 30, 2010 | 05:35 AM
so:
engine
gearbox
loom
and mounts?
radiator etc all the same?
Old Nov 30, 2010 | 07:47 AM
9599civicguy's Avatar
Default whats a good build up for a 95 civic
whats a good build up for a 95 civic to play with on the street ? thanks for any help
Old Nov 30, 2010 | 12:55 PM
98civdx's Avatar
Master Detailer
The radiator will work, you just will need to use different clamps on the radiator side.
You will also need, b series axles, shift linkage.
You can use your orginal harness if, you add all the proper wires... depending on the ecu you get you may need to get a jumper harness as well.
Datboiimfamous
Dec 15, 2009 11:20 AM
jasony0630
Dec 23, 2007 10:11 PM
JayDM_EK9
Mar 25, 2005 06:41 AM
nyteflyte2003
Dec 2, 2004 12:17 PM
