how to preform a leak down test
Old Nov 28, 2010 | 03:42 PM
flipldls's Avatar
Default how to preform a leak down test
just making sure do you have to set the engine at tdc before performing a leak down test, or would you need to do each cylinder individually at tdc( if that makes any sense)
Old Nov 28, 2010 | 04:41 PM
luck4rmkc's Avatar
Default Re: how to preform a leak down test
Well you want the valves to be closed on each cylinder when you perform a leakdown test. So each cylinder must be a TDC compression stroke as you test each cylinder. Or, if you have the cams out, it won't matter because all valves will be closed.
ParadoxTeg
May 5, 2015 04:55 PM
92integraVTECgsr
Nov 20, 2005 01:02 PM
silverEH2
Oct 14, 2003 11:54 AM
jeremy.
Sep 26, 2003 09:03 AM
lazy bum shaughn
Jan 28, 2003 07:55 PM
