Paint for calipers/valve cover?
Old Nov 27, 2010 | 12:19 PM
coolharry's Avatar
Default Paint for calipers/valve cover?
I have to rebuild my calipers in the next few days and figured it might be a good time to paint them and maybe the valve cover if I can find the time and its not to expensive.
What are my options if I want to paint them to match the car color (milano red)?
Can I use regular automotive paint if I use a high temp primer?
Old Nov 28, 2010 | 10:35 AM
coolharry's Avatar
Default Re: Paint for calipers/valve cover?
anyone?
Old Nov 28, 2010 | 02:22 PM
Empyre JDM's Avatar
high temp paint is coo for your calipers and your valve cover
i remember when i had my DC i sprayed my valve cover red with just some Rusto spray can.. lasted me foreever..
Old Nov 30, 2010 | 01:31 PM
coolharry's Avatar
But what about regular automotive paint? Like from PPG?
I've searched all over HT and only found a few posts about it, but nothing with a definite answer.
Old Nov 30, 2010 | 04:42 PM
Hawkze_2.3's Avatar
I can answer that for you for sure; regular automotive paint will be fine
I actually did a test spot on my engine block right behind the exhaust header with some PPG OMNI single stage, and after a year nothing has happened to it. No discoloring, no peeling, no nothing. Valve cover and calipers should be just fine as long as the prep is done correctly.
I've also used POR-15 on brake calipers and it was fine as well.
Old Dec 1, 2010 | 06:55 AM
UzziAirbrushing's Avatar
id just use a heat resistant clear over it they have some they sell thats made for high heat like headers and stovetops even thats clear. just google heat resistant auto paint, i forgot the exact site
Old Dec 1, 2010 | 06:59 AM
00siboy's Avatar
high temp wrinkle paint
Old Dec 1, 2010 | 11:55 AM
Empyre JDM's Avatar
it will all work fine, i just went into autozone and picked up some heat resistant spray cans
for my truck calipers and they have lasted forever still on there and the paints been there for about 3 years now. even when brake dust etc gets on them i just spray them down.
Old Dec 3, 2010 | 11:04 AM
coolharry's Avatar
Awesome. thanks man!
Old Dec 9, 2010 | 04:16 AM
ymcboss's Avatar
good thing i read this i was about to buy a spray can and star painting..
Old Dec 9, 2010 | 06:29 PM
prelude1897's Avatar
I painted my valve cover and calipers with regular car paint(base coat/clear coat) simply cause I have a lot of paint I need to get rid of and everything has been working perfectly fine. No chipping or discoloring happening at all
Old Dec 15, 2010 | 10:52 AM
Markb16a's Avatar
what about powder coating your calipers will this work to? I am thinking of having some get powdercoated.
Old Dec 15, 2010 | 04:54 PM
sc34dc4's Avatar
^^^ yes it will be fine. It's been done 1000X but why when you can just paint them and have the same outcome for cheaper.
Old Dec 20, 2010 | 05:33 PM
toeout's Avatar
I used VHT hi -Temp Wrinkle paint on my valve cover. It takes a long time to cure, but looks absolutely great.
From Advance Auto:
http://shop.advanceautoparts.com/web...%7CGRP2050____
-=ZAK=-
Jan 15, 2009 07:42 PM
sean2000gt
Paint and Body
10
Oct 12, 2008 04:36 PM
1JDMDOMINICAN
Mar 19, 2006 04:06 PM
jsteezy1290
18
May 12, 2004 08:59 PM
infamousALLMTR
Feb 17, 2003 09:57 PM
