Help turn signals not working
I recently replace my OEM bulbs with LED for my side markers and now my turn signals aren't working.
I checked the fuse #7 and its fine, i even swapped it with another 7.5a fuse and still not working.
My hazard works fine. I tried swapping the OEM bulb back and re-plugging the hazard as that was suggested in another forum with similar problem and still no signal.
Please help if you have come across this similar problem as i do use my turn signals often. /sadface
i opened up the flasher relay and dont see anything wrong with it.
im thinking about trying this http://cgi.ebay.com/ebaymotors/ws/eB...m=290488787604
or maybe buy a new flasher relay to test out
edit: i fixed it !! turns out it was the hazard button. it would get stuck in some weird way and not allow me to use my signals but will let me use my hazards. now when i use my hazard i have to carefully press the hazard a few times with my signals on until i see my signals working. I think the hazard button is full of dust and may need to be replace or cleaned.
