how do you lower your steering column in a crx??
so im changing out my heatercore and i cant find out how to lower my steering column so i can get my dash out of my car. i dont want to take off crap if i dont need to. this is my 1st time taking off a dash and it was a pain in the *** taking off the wiring harness adapters by the fuse box.
EDIT..
you don't have to drop the steering column. i never did, because the real thing thats in the way is the wiper/turn signal switches
get on the floor on your back and look up.
there are 2 bolts and 2 nuts on long studs that hold the steering column up. they are attached to plates that are welded to the steering column. get out a flash light. as soon as you see it, you'll kick yourself for how obvious it is
i put everything back together but now its like when i start the car its choking and not wanting to start....what can this be??
you dont have to take off your steering wheel to take your dash out. Just lower your steering column and just wiggle the dash out, I think your making it more difficult than it should be.
Taking out the dash is one of the simplest things to do, just use common sense and I'm sure someone has already covered on how to take out the dash. Google is your friend, I just type Honda Tech and what I'm looking for.
From: Close to West Chester, PA, United States of America
This thread shows you how to drop the whole thing. Don't know if you have to though...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/manual-pedal-cluster-auto-car-1220898/
my main relay works because i had problems with it before and spent 300 bucks trying to find out what my problem was. i know the main relay is good because when you turn your key the relay will hummmmmmmmmm and it does that. there is a good engine diagnoses i was looking at and it has some good info.
http://www.aa1car.com/library/us1296.htm
DXDOHCVTEC
Jul 20, 2004 09:09 PM
Eg_Lover
Jul 15, 2004 04:50 AM
