Overheat! Problem! HELP?
My turbo accord is overheating like crazy. Setting at idle the car runs fine. As soon as I drive for about 5 mins or so it starts to overheat fast. I Just replace the headgasket after the first overheat. But the problem is still there. Note im only boosting 5 psi. Also when my VTEC kicks in the car sounds a little funny. It doesn't sound like it did before. I changed out my themostat, i check for cracks in my radators already. Also I water pump is pumping, due to the fact that on my bleeder bolt near the themostate im getting a constant flow of water. Note the flow os water is kinda strong coming out of the bleeder bolt. Also when i take the radaitor cap off i notice little bubbles coming up, but it doesn't do initially. I think it meant be a crack head.........?? Any comments would be grateful thanks.
[Modified by NXAccordTO4B, 8:45 PM 9/22/2002]
mastakmk
Apr 14, 2008 08:54 PM
jedubz
May 6, 2004 08:43 PM
