Removing emblem adhesive
Old Nov 24, 2010 | 01:31 PM
97CWITR's Avatar
Default Removing emblem adhesive
Took my old emblem off, and I have the adhesive on the front bumper.
What's the best way to remove it without harming the paint?
Thanks!~
Old Nov 24, 2010 | 01:35 PM
gorillafart's Avatar
Default Re: Removing emblem adhesive
EUREKA!!!!!!!!!!!!!!!!!!!!!!!!!
adhesive remover???????????????????/
Old Nov 24, 2010 | 01:38 PM
ninjaturtleEG's Avatar
I'd use a heat gun. But be careful with that because it takes a while to heat up but once it does it can get really hot. Or if you have a propane or oxy/acetylene torch. But ya I'm sure you won't overheat but if you do you wont just harm the finish but you might **** up the molecular structure of the metal underneath and weaken it or you might shrink it and cause oil can effect.
Old Nov 24, 2010 | 03:17 PM
jasoncrashtech's Avatar
adheisive remover. let it soak, work it off with something that won't be harsh on paint but dont directly ruff the paint
Old Nov 24, 2010 | 03:34 PM
NOFX's Avatar
H-T White Ops
Adhesive remover. You can find it at Autozone for a couple bucks.
When the adhesive is really hard sometimes I'll use brake cleaner (not fluid) to get it off fast and then rinse the area and wax it.
Old Nov 29, 2010 | 04:54 PM
Bseriez's Avatar
about to do this myself
Old Nov 30, 2010 | 07:28 PM
-16V-'s Avatar
Check out the link. This is what i use at the dealership. Its not honda related, its just to give u an idea.
http://www.chargerforums.com/forums/...d.php?t=107803
Old Dec 3, 2010 | 11:21 PM
MERC6372's Avatar
i got mines off with coca cola and elbow grease lol
Old Dec 4, 2010 | 03:02 PM
Darklord's Avatar
Try a tar remover or some wd40.
kilroy79
Jan 23, 2008 12:43 PM
5Point7Liter
Paint and Body
Sep 17, 2007 10:46 PM
rukawa1one
Jan 9, 2007 02:47 PM
jweezy225
Jul 11, 2004 01:02 PM
hybridb18
May 2, 2003 11:03 PM
