How to remove paint overspray on rubber window trims?
As long as I dont have to take out any more Metal Gears
Like the topic says, I have a little overspray on the rear rear window rubber, how do I remove it from the rubber? Searched but all it had was how to remove overspray from surfaces that are already painted. TIA
Re: How to remove paint overspray on rubber window trims? (rukawa1one)
freind used nail polish remover, it wasn't alot of over spray tho and wasn't to thick so
if its fresh paint, use some Prepsol (wax and grease remover) your going to need a lot and scrub the rubber with a rag soaked in it, it will soften up and you should be able to eventually rub it off.
If the paint is well and truly baked now, i would use thinners and a rag, but stll, i would mask off the areas around the rubbers to be sure
Re: (tegdude227)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 »</TD></TR><TR><TD CLASS="quote">use 3m remover you can use it on paint trim rubber </TD></TR></TABLE>
Where can i get this product?
rbanke
04-07-2006 06:53 AM
