1993 Transmision Issue
Old Nov 22, 2010 | 01:16 PM
M20Curtis's Avatar
Default 1993 Transmision Issue
I have a 1993 accord that won't up shift once the car has been running for 10-15 minutes. It will down shift with out a problem but then won't shift past second gear. But then at other times it will shift quickly back and forth between first and second for no apparent reason.
Is this an electrical problem or transmission problem?
Old Nov 23, 2010 | 04:58 PM
poorman212's Avatar
Default Re: 1993 Transmision Issue
When was the last time the fluid was changed, or level checked?
Are there any stored codes in the TCU or ECU? D4 light on, blinking.
If all of the above check out, guess what...I'm betting the tranny is dead. Sorry.
Old Nov 24, 2010 | 05:34 AM
Crx dude's Avatar
tranny filter is probably plugged up.
Wheelman-CZ
Jun 8, 2006 05:10 PM
AgentofDarkness
Jun 3, 2006 07:47 AM
sohc prelude
Feb 26, 2006 07:26 PM
skunk2unerz
Sep 4, 2003 06:05 PM
boomslang
Nov 18, 2001 12:00 AM
