Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2007 Pilot Keeps Vibrating??
Old Nov 21, 2010 | 07:10 PM
Jibin's Avatar
Default 2007 Pilot Keeps Vibrating??
So I have an 07 Pilot EX FWD and when the car is at idle the car will vibrate like crazy, it sounds like I have subs in the car and when you give it a little gas it stops. The idiots at the dealership can't find out what it is so I was wondering if this has happened to anyone before?
Old Nov 22, 2010 | 03:59 AM
TODAwhore's Avatar
Default Re: 2007 Pilot Keeps Vibrating??
check your front and side engine mount.. I see a lot that needs replacement around the 70k to 100k mileage mark.
Old Nov 22, 2010 | 11:12 AM
CountDracura's Avatar
The symptoms sound like motor mounts to me. Re-torque them to spec or replace the broken mounts if they are worn.
Old Nov 22, 2010 | 04:05 PM
Jibin's Avatar
The thing is when you open the door the noise goes away?
Old Nov 28, 2010 | 06:29 AM
jazacher's Avatar
So Just shifting the weight inside a little makes it stop? Where do you heard it when you are outside. It does sound like motor mounts from what is listed here.
Old Nov 28, 2010 | 08:58 PM
Jibin's Avatar
Its coming from the inside
Old Dec 6, 2010 | 09:01 PM
egtwincam's Avatar
Sounds electrical. Try to relearn the idle with hds scanner.
Old Dec 12, 2010 | 10:50 AM
p10hlm's Avatar
Sounds like you should take it to another dealer if they cant figure out the active sound control issue your describing.
i hope you dont think that just because your taking it to a dealer your getting a "professional" to check it out.
Old Dec 25, 2010 | 08:39 AM
Jibin's Avatar
Anyone else?
Old Dec 28, 2010 | 09:32 AM
hmt_whiterice's Avatar
Door gap width the same on all sides? Latching properly?
Old Dec 28, 2010 | 02:06 PM
so simple's Avatar
is the noise coming from the car/motor or from the speakers? i dont know if the car has the noise cancelling technology thing like the TLs. if so, maybe its faulty?
i remember i worked on a new at the time 08 TL type s, when you add on aftermarket amp sub, the noise cancelling would mess with the subs, making it vibrate, took a while to figure out we had to disconnect the noise cancelling mics.
VTECcnIT
May 10, 2006 12:29 AM
Sleepy_Red_hatch
25
Dec 20, 2005 05:17 PM
STEALTHMODECOUPE
Sep 20, 2004 03:01 PM
95lsinteg
Feb 7, 2004 12:08 AM
blueeg
Aug 6, 2003 03:35 PM
