mini me still not working.. >:[
Old Nov 18, 2010 | 04:26 PM
chrysanderson's Avatar
Default mini me still not working.. >:[
its been like 3 months since i started doing the mini me swap. i have everything wired up.the p28 ecu hooked up with the jumper.the injectors wired up.distributer wired up. EVERYTHING!
anyone got any ideas as to why the car wont start?
Old Nov 18, 2010 | 04:30 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: mini me still not working.. >:[
start by diagnosing the problem, do you have any spark? are you getting fuel? figure those things out and then I can help you.
Old Nov 18, 2010 | 04:36 PM
Marcos Barrios's Avatar
double check your timing as well
Old Nov 18, 2010 | 05:17 PM
efjones9's Avatar
does it crank ? give us more details and we can help u better bro
Old Nov 18, 2010 | 09:50 PM
i am gettin fuel,spark and compression.
it cranks but wont turn over. and we've done timing twice jus to make sure.
Old Nov 18, 2010 | 09:51 PM
Loved
Community Favorite
injector wires mixed up? plug wires mixed up?
Loved
Community Favorite
also if it has any codes like code 4 for the crank position sensor it might not run.
Old Nov 18, 2010 | 09:55 PM
nah i got the injector wires right. i kno that much.
ima have to look into that code thing tho. but im 100% sure the dizzy is wired right also.
would be better just to take to shop an have them figure it out?
Old Nov 19, 2010 | 07:45 AM
low&slowef's Avatar
just throwing this in there i have a bad injector and it tends to not wanna start up so in coulld possibly be your injectors.
Old Nov 19, 2010 | 08:24 AM
efjones9's Avatar
u should test ur inj wiring agian with a test light. when u crank it the test light should turn on and off in a rythmic pattern, if it just stays on there is a prob with ur inj wiring. also take ur dizzy out then thun the rotor 180 degrees then install it and try agian
or just hold the gas pedal all the way down when cranking it. that worked 4 me numerous times sounds dumb but it worked
Old Nov 25, 2010 | 10:34 PM
thanks for your guys help. im jus gunna let the civic sit till i get outta UTI an kno my stuff. i jus picked up a rx7 today soo ya.
G. Man
15
Apr 8, 2011 08:06 AM
gsrboost737
Apr 16, 2009 11:38 PM
2ltrtodd
Jan 23, 2008 12:18 PM
UNDER PRESSURE
Oct 23, 2007 12:34 PM
tdo
Oct 2, 2005 09:39 PM
