crx d16z6 turbo help
Old Nov 18, 2010 | 03:33 PM
rcboy2793's Avatar
Default crx d16z6 turbo help
i have a 90 crx si with a d16z6 swap t4oe turbo, 525cc injectors , any way i have a chiped ecu thats base maped for 525 injectors . when i cold start the car it wount idle till it gets warm. my air fuel says dead ritch. then ounce it gets warm and i try to drive it when it comes off boost and i push the clutch in it shuts off. is my problem all in the tune??or somethin else
Old Nov 18, 2010 | 06:21 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: crx d16z6 turbo help
sounds like its the tune. any check engine light? if so code them out and go from there. is it obd1 converted or still obdo?
Old Nov 18, 2010 | 06:57 PM
rcboy2793's Avatar
ther car is a obd1 swap. and no it usually dosnt set the cel . except on the way home yesterday it did . was a solid cel
Old Nov 19, 2010 | 08:28 AM
lsturbo33's Avatar
Fix the cel. Tune the car. You shouldn't even be driving around or building boost on the basemap.
Old Nov 19, 2010 | 05:36 PM
KWayRacing's Avatar
Very very true.
Old Dec 9, 2010 | 03:06 PM
redjeep303's Avatar
why are you not suppose to be boosting on the basemap?
Old Dec 9, 2010 | 05:04 PM
nonvtecD's Avatar
Basemaps are for starting a turbo car and driving to a tuner. At least get it street tuned. If you have a wideband you're good to go. What EMS are you running?
Old Dec 9, 2010 | 05:36 PM
Loved
Community Favorite
not necessarily. ignition timing is much more crucial to a motors life. if his ignition timing is advanced 5 degrees it could be the end of his ringlands.
Old Dec 10, 2010 | 06:08 PM
nonvtecD's Avatar
You can set base timing with a timing light and then retard it under boost with any good EMS...
Old Dec 11, 2010 | 03:57 AM
Loved
Community Favorite
ya i know this but saying if you have a wideband your good to go doesn't let him know that he needs to set base timing and worry about his ign timing...
Swerve_EG
Oct 16, 2014 12:00 AM
MagicJ_2000cx
Engine Management and Tuning
Feb 3, 2014 01:24 AM
rcboy2793
Mar 18, 2011 06:09 PM
hatchaneg
Dec 19, 2008 03:38 PM
Rease3
Jun 10, 2008 03:42 AM
