NGK Powerdex
Old Nov 18, 2010 | 05:26 AM
rich7777's Avatar
Default NGK Powerdex
Hey guys,
Just a quick question about the NGK Powerdex. Can you wire it to the stock ecu and use it with Ectune or any other software like you can with the LM1 or PLX ?
Thank guys
Rich
Old Nov 18, 2010 | 06:53 AM
GhostAccord's Avatar
Default Re: NGK Powerdex
Not a stock ECU. The NGK has a 0-5v output, therefore, your ECU has to be modified to read a clean 0-5v input signal. I have modified a few OBD1 ECUs to run the NGK Wideband with eCtune. There are a couple different pins/circuits that you can easily modify to have them allow for a 0-5v signal.
Old Nov 18, 2010 | 07:00 AM
rich7777's Avatar
Yeh sorry thats what i ment, you use EDL as a input don't you ? Does it take long to wire in and setup ?
Old Nov 18, 2010 | 07:17 AM
ELD works, there are a couple that you can convert to run 5v
What do you consider long? It really depends on your comfort level with electronics and taking apart your interior. The last one I hooked up took me the morning (3-4hrs) from start to finish, permanent install, no wires hanging loose. That's also including modifying the ECU. If it's your first time and your interior is intact, you could be looking at up to a full day. Again it depends on your level of mechanical/electrical know-how.
Old Nov 18, 2010 | 10:32 AM
rich7777's Avatar
I was going to use it to tune mutiple car's with. I might just stick with me LM2....
janz3n
May 1, 2006 08:12 PM
intekragsr
Apr 27, 2005 10:12 AM
intekragsr
Audio / Security / Video
18
Apr 20, 2005 11:06 PM
dornon13
Aug 13, 2004 12:55 AM
Inkrazy
Mar 7, 2004 10:22 PM
