96 Civic coupe - Turn signal does not work when brake pedal pushed
Old Nov 17, 2010 | 10:03 PM
zeusdb1's Avatar
Default 96 Civic coupe - Turn signal does not work when brake pedal pushed
I recently purchased a 96 Civic Coupe. My problem is that when I step on the brake the right turn signal would come on in the dash! When I signal right and step on the brake the light stops blinking, it just stays lit. I haven't been able to check if the lights on the rear change as well. Any ideas?
Old Nov 18, 2010 | 05:56 AM
Former User's Avatar
Default Re: 96 Civic coupe - Turn signal does not work when brake pedal pushed
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
The first thing to check in this situation is whether the wrong brake/turn signal light bulb was installed. It should be a double filament, not single filament, bulb.
Old Nov 18, 2010 | 05:59 AM
MR.johnson's Avatar
bad ground.
Old Nov 18, 2010 | 10:28 AM
Skunk2Joe's Avatar
check your fuses and your wiring, sometimes when people use aftermaret tail lifhts the piggy back that they use causes more problems then they are worth, now im not sure if that is your problem, but its a good place to start. I had the same problem on my coupe, and that was why. Hope that helps
Old Nov 18, 2010 | 03:04 PM
zeusdb1's Avatar
turns out to be a bad ground. thanks for all the help.
Old Jan 17, 2011 | 11:41 AM
Talldog's Avatar
I have this same problem. It's driving me nuts. Where did you find the bad ground and how did you fix it ?
PDXHatchback
Jan 15, 2013 04:36 PM
Civicgirl_21
Jan 15, 2013 08:23 AM
Ekevans08
Jan 6, 2013 10:57 PM
ShowSpeed
Apr 4, 2006 08:06 PM
