94 del sol/B16 with 165-175 psi cylinder compressions - Is this good?
So I have a 94 del sol with a b-16 and just did a compression test. It came up between 165 and 175 psi. The motor has 243 thousand miles. Is that good compression or what?
It gives you an accurate reading plus it fills the cylinders much faster . The last thing you want is numbers all over the place. It is the PROPER way of doing a compression test.
The throttle angle directly affects the cylinder pressure when the intake valves close, so it'll affect your cranking pressure too.
The engine was warm I did the cylinder closest to the distributor first it was 175 second was 173 third was 168 and 4th was 165.
luvmihatch
14
Feb 5, 2011 09:43 PM
cleaned throttle body on '94 del sol S, now my gas mileage kinda sucks and hydrocarbon output is out
Neptronix
Feb 1, 2008 11:11 AM
ShagNastyEK9
May 23, 2007 05:44 PM
prodigalson
Jul 23, 2004 04:49 PM
