Shave Engine Bay FAQ
Old Nov 17, 2010 | 07:04 PM
dev203d's Avatar
Icon2 Shave Engine Bay FAQ
Is there a thread on shaving the bay anywhere? Do I just weld shut the holes and bondo over? I'm a bit confused. I searched and found nothing so thanks guys!!!!
Old Nov 17, 2010 | 07:24 PM
sc34dc4's Avatar
Default Re: Shave Engine Bay FAQ
I think it's in the paint and body section. Yes you are correct though. Use a wire wheel to get the area to bare metal. Weld the hole shut and grind down the weld. If you do a good job then you can skip the bondo and just use icing on the area. Sand down and re apply if 1st coat didn't do it "usually takes 2-3 since icing is so thin". Hit it up with some primer out of a spray can to see imperfections and fix if needed. Repeat repeat cuss drink cuss and drink more repeat repeat
Old Nov 17, 2010 | 10:46 PM
disboiflaco's Avatar
^^ yup what he said.
Old Nov 18, 2010 | 01:29 PM
toyomatt84's Avatar
Sanji
https://honda-tech.com/forums/honda-acura-28/shaved-tucked-customized-engine-bays-pics-theory-discussion-1693934/
Old Nov 18, 2010 | 02:37 PM
seanclark's Avatar
hoe do most people smooth out the seams in the engine bay ? is it a case of building up some weld along the seams and grinding down till smooth then a skim of filler ?
alltech_hybrid
Paint and Body
38
Mar 13, 2018 10:16 AM
digital sol
Paint and Body
Mar 7, 2012 09:19 PM
LilTeggy2011
Appearance Build Threads
Apr 19, 2010 05:24 PM
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
texaszcrx
Mar 25, 2009 02:53 PM
