fully built n boosted 93dx civic coupe
im posting for a friend. hes not a ht member. you guys can pm me or text me whatevers easier for you. pics will be up in a day or two for now this is all i could post. these parts must go asap but please keep your best offer reasonable. 915-920-1684
2200 obo 93 civic dx shell fresh black paint job new windshield. all body panels headlights taillights all glass intact no front or rear seats does have dash and cluster. stock suspension will include the big 4 lug conversion 4x114. cross drilled and slotted rotors front and back with new pads
2400 AFI complete turbo kit with the bottom mount tubular manifold, t3/t67 ball bearing water cooled turbo,PWR intercooler, dual tial 38mm wastegates,50mm tial bov.
1600 b18a1 ls block sleeved and assembled with arias 9.2comp pistons eagle rods itr oil and water pump. will come with oil pan already tapped for boost
1300 jdm 98spec itr transmission. i had my dad check my invoices back home to make sure it was a 98spec. can get copy later on
750 complete b16a head stock ports with cam caps and cam rails vtec solenoid black valve cover sensors and all. basically a complete top end motor
skunk2 intake and exhaust valves
skunk2 11k dual valve springs
skunk2 titanium retainer
skunk2 stage 2 cams currently not installed/running ctr's
skunk2 adj cam gears
p73 itr intake manifold
p72 gsr throttle body
500 hondata s300
250 ACT 6puck unsprung clutch disc and race pressure plate
200 msd 6a box, msd coil, msd cap and wires
50 motec 3bar map sensor
100 walbro 255lph fuel pump
300 rc 750cc injectors with resistor box
*sold koyo aluminum half radiator
*sold slim fan or 150 for both ^
150 skunk2 LCA's
100 skunk2 front camber kit
*sold tein ss 16way adj complete dampers or 750 and stock springs n struts
600 buddy club seats non reclinable with rails n sliders
150 jdm audio console
might be some other stuff i cant remember off the top of my head.
500 hondata s300
150 skunk2 LCA's
ttt, a big detail i forgot to mention is this entire set up only has 15xx ish miles or so. i have reciepts for everything !
gsp ej1-em1
Northern California (Sales)
17
Apr 1, 2007 05:24 PM
dirtyEj1
Texas -OK -LA (Sales)
Feb 13, 2007 09:40 PM
turboex
May 15, 2003 08:11 AM
