any turbo daily integras out there
Old Nov 16, 2010 | 06:28 PM
98tegLSvtec's Avatar
Default any turbo daily integras out there
hey guys just wondering what kinda setups your running, what motor,internals,gas milage on setup etc.etc.etc... thanks
Old Nov 17, 2010 | 08:12 AM
Default Re: any turbo daily integras out there
theres gotta be someone out there with a good reliable setup thats amazing for dailying...
I have an ls/vtec motor fully built with low compression.(motor)
I also have a ramhorn mani and .60 trim garett turbo jdm sport ic piping 450cc blue tops(boost setup)
but this spring im thinking about selling one of my integras and paint the other one,putting a nice exhaust system on it, and then use it as a super clean turbo daily
Old Nov 17, 2010 | 10:51 AM
fv8s's Avatar
I have a friend that daily's his DC2 making 500 wheel. 3 years with the same motor just pistons and rods and it has yet to leave him stranded.
Old Nov 17, 2010 | 12:17 PM
lsturbo33's Avatar
Stock internal ls motor with arp headstuds. turbonetics 57trim 300whp. It's been like that almost a year with no problems.
Old Nov 17, 2010 | 02:02 PM
Dang thats rediculusly awesome!
Old Nov 17, 2010 | 02:06 PM
First off I like your setup! if i were to start over thats what i would have! Keep things real simple, May i ask how many pounds?
so pretty much i should be good with around 350whp all day in the fully built ls/vtec not that i need that much power but lets face it my motor is made for it, And them cocky people with there "Factory Sports Cars" built in the US hahah
Old Nov 19, 2010 | 06:45 PM
and the second part of this question would be, What turbo would allow for over 300 hp, but still be mainly trq. and good for a 9:1 compression motor. Just trying to evaluate my setup for this spring.lol
Old Nov 19, 2010 | 06:55 PM
justin.parker's Avatar
I daily my gsr @400 wheel. It's not really that bad to daily a honda with that much torque, it's actually relatively nice at freeway speeds to have the torque to pass and not worry about it. Boost by gear, lsd, and decent tires at that level are almost a requirement however. If I had 400 in every gear I think it would be kinda difficult.
A 57 trim t3/t4 should be more than enough for what you want while still allowing you to push it later. We all know that you will want to.
Old Nov 19, 2010 | 07:05 PM
Well first off I completly agree with you, but my car has been turboed for 2 years now with 3 different setups, im just havent found one that im 100% about, i had the ebay 50trim loved the response of it and was considering going back how do you feel about that?
And as far as the whole I would want more boost its true in a sense, but im more or less conservative due to having to suport this hobby myself (no rich parents here) and i would prefer to get my time and use out of it if uk what i mean. started with 5psi first setup bumped it up to 8psi on the second setup everything was grand. and now with a fully built low compression ls/v and a .60trim garrett still only at 6-8psi
Old Nov 19, 2010 | 08:24 PM
Jimmy's Avatar
Global Moderator
I ran a jdm b20b tuned on 93 octane up to 10lbs on a .57 trim t3/t04e (drag 3 kit)
It ran great for over a year and a half daily driven and long road trips.. in my opinion it's all in the cooling system (good radiator, nice fan setup, and fuel management & tune)
Just be sure to keep up with routine maintenance.
Old Nov 20, 2010 | 12:05 AM
In my opinion there are plenty of choices for the power goal you are looking at. If you already have a 50 trim then why not run with it. I was only speaking on behalf of my setup. Get a good tuning software/tuner and you can make a streetable setup at just about any power level if you wanted.
Jimmy is completely right though, longevity relies on tune and cooling. If you have those squared away why not talk to the tuner and ask his/her opinions? They are going to be the ones in the nitty-gritty on your setup.
As to your other question I completely know what you mean. It took me a year to put together my setup and I completely understand about wanting to get the time and use out of it. Whether or not you pick a 50 or a 57 trim turbo is a mute point, pick a setup that fits your budget and gets you the goals you are looking for.
Boost is addicting, turbo hondas are fast. What more could you ask for? :D
Old Nov 20, 2010 | 11:56 AM
I agree 100% thats why i wanna find a real good tuner thinking about going with king
Old Nov 20, 2010 | 12:01 PM
I had a a 50trim now its a 60trim garrett and its just a bit laggy for me i guess its just due to the fact i have always loved a trq>Hp car but have yet to have one. A buddy of mine had a eclipse turboed LS with gsr trans, it was super cheap setup and so much fun to drive!! and i guess i wanna setup something like it but that can produce boost all throughout the power band
Old Nov 22, 2010 | 05:54 AM
lsturbo33's Avatar
13 psi for me. The 60 trim is a nice turbo for the gsr. You should keep it and turn the boost up since you already have it.
Old Nov 22, 2010 | 11:21 AM
If the 60 trim is a little laggy, what kind of power output are you looking to get towards and what kind of money are you looking to spend? Something like a gt28r would give you a good spool time, boost through most of your rev range and still produce some power output.
I understand wanting something with some torque but trying to get a honda to be a torque monster is somewhat of an uphill battle. 400 ft/lbs @ 1k rpm just is not going to happen. With my setup at cruising speed in 5th I can roll into the throttle and have more than enough torque to do whatever I need.
Old Nov 22, 2010 | 06:52 PM
[QUOTE=lsturbo33;44067455]13 psi for me. The 60 trim is a nice turbo for the gsr. You should keep it and turn the boost up since you already have it.[/QUOTE
i would but ive only got 450cc injectors
Old Nov 25, 2010 | 07:08 AM
ik theres people that are gonna hate, but here goes: how do u guys feel about a .50 trim off ebay?
Old Nov 25, 2010 | 07:20 AM
Lord Helmet's Avatar
.5 trim is a very good choice for a daily IMO (Boosted daily driver B18C DA). fast spool coupled to a .63 housing is ideal for me. Very easy to make 300whp. Remember keep the cooling temp down and tuning is key here for reliablity.
Old Nov 26, 2010 | 04:01 PM
ik its a great turbo! had a ebay .50trim with 5psi and E85 i made 250whp! but my question is should i rock the ebay turbo, there good until like high 3xx right im shooting for 350whp but i only hit full boost rarely!
Old Nov 27, 2010 | 06:25 AM
thun123's Avatar
getting turbo'd soon once i get this ls v goin
Old Nov 27, 2010 | 06:54 AM
nice! what kinda turbo setup you going with ?
vteg94
Oct 29, 2008 10:03 PM
DA_Manny
Nov 6, 2007 03:35 PM
jamescb77
Mar 8, 2007 11:40 AM
*Boostwerks*
Jul 5, 2005 12:48 PM
