how do you make a vx lean burn all the time?
Old Nov 16, 2010 | 05:12 PM
83gs1100g's Avatar
Default how do you make a vx lean burn all the time?
just play'in around for kicks to see what the mpg's would be if in lean burn all the time(3 valve mode) and not in lean burn(4 valve mode)? Is this easy enough to do without gettin to crazy of a mod? Right now I just have the wire from the spool valve pulled and it feels like its in not in lean burn but won't know till I check my mileage. Like I say just for kicks to see what mpg's are? Anyone every tried this?
Old Nov 16, 2010 | 05:56 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Default Re: how do you make a vx lean burn all the time?
You need to research this to learn that lean burn at the wrong RPMs doesn't improve gas mileage / fuel economy.
Your homework, READ: http://www.gassavers.org/showthread.php?t=2427
Old Nov 16, 2010 | 06:09 PM
93egSLEEPER's Avatar
Im sure Honda does this on purpose and messing with the valves and fuel flow will lead to larger issues later on.
Old Nov 16, 2010 | 08:55 PM
kaiba's Avatar
What is your current mpg? Just curious.
Old Nov 19, 2010 | 09:23 AM
83gs1100g's Avatar
So I take it no ones ever done this or tried it? With the spool valve plug pulled she runs with both intake vales all the time and runs very nice I might add but mpgs are around 40. Can't figure how to make her run on one intake valve all the time?
Old Nov 19, 2010 | 10:47 AM
94EG8's Avatar
Seagull Management
Either disconnect or supply power to the vtec solenoid all the time, can't remember which. It'll choke over about 2500rpm.
jrlink2k
Honda S2000
Feb 14, 2020 03:05 PM
mouab18c1
Engine Management and Tuning
17
Jul 29, 2012 01:08 AM
89civichb
Mar 2, 2009 02:39 PM
SoullessJapaneseMachine
Jan 23, 2008 07:33 PM
Rory Breaker
Mar 12, 2003 09:45 AM
