an fittings size
hello, i want to replace some of my oem fittings/hoses with an fittings and braided lines but i dunno whats the correct size to order for either an fitting or flare fittings.
I want to change the following parts:
1. The hose that goes from the fuel rail to the fuel filter(whats the size of that hose and what an fitting i should use).
2. The hose from the fuel rail to fuel regulator
3.The hose that goes from the brake master cylinder to my g.e. vacuum manifold
4. The hose that goes from the vacuum manifold to the back of the intake manifold
anyone knows the oem hose sizes? I really dont understand how an fittings/hose sizes work and i dont want to order them and in the end to be oversized. Note that i live in EU and there are different metric methods here so thats the problem why i cant find the hose sizes
thanks
thanks
This will help you understand AN sizes
http://www.anplumbing.com/thread.html
And i'll guess at your list:
1.) -6
2.) the vac hose? -3
3.) -8 or -10
4.) -8 or -10 as well
1.) -6
3.) -8 or -10
EscoSi
Aug 13, 2013 09:10 AM
FwdCivicHatch
May 29, 2004 03:50 PM
