93 civic b18c swap COLD START DIES
Old Nov 15, 2010 | 07:52 PM
f22vtec1's Avatar
Default 93 civic b18c swap COLD START DIES
my buddy's car when its cold it will fire but die immediatley unless you give it gas for about a min then it'll barely idle of course unless u pull the vacume from the fpr then it idles fine but not the issue i dont think
it has no cel's new fuel filter fuel pump primes he took off iacv to clean it but to no avail havent tried another ecu yet but i dont see that being the issue since the car still runs after its warm and it doesnt throw a cel
any ideas would be greatly appreciated ? he thinks its the iacv but i told him no sense in wasting 200 bux on a new one just taking a wild guess
Old Nov 15, 2010 | 09:33 PM
f22vtec1's Avatar
Default Re: 93 civic b18c swap COLD START DIES
any ideas ?
Old Nov 15, 2010 | 10:21 PM
f22vtec1's Avatar
just for more info
new plugs , wires, cap & rotor... great compression 220
runs good after warmed up but cold start it just wont stay running unless u give it gas for a minute then it'll hold a low idle
Old Nov 16, 2010 | 07:58 AM
blkcivic310's Avatar
subscribe for answer mine does the same thing if i give it gas it will kick up and run perfect it idles at 500+ and will start fine the rest of the day
Old Nov 16, 2010 | 01:30 PM
f22vtec1's Avatar
wow no one has any help ? hmmmm ok
Old Nov 16, 2010 | 03:39 PM
apexi_rsx's Avatar
i have this problem with my turbo z6 but i think i blame it on the t/b and having no fitvand the iacv wont open enough
Old Nov 16, 2010 | 03:42 PM
f22vtec1's Avatar
but if it worked fine before i dont think u can blame that cuz it never had a fitv to begin with
Old Nov 16, 2010 | 05:52 PM
93egSLEEPER's Avatar
Clean your IACV and TPS. Sounds like its smothering itself.
Old Nov 16, 2010 | 06:21 PM
f22vtec1's Avatar
cleaned everything that we could think of ...
that allen type screw on the side of the iacv is not there ! just realized that what does that do ?
Old Nov 16, 2010 | 06:39 PM
Its creating a vacuum leak. get that hole plugged and it bet it will run perfect.
Old Nov 16, 2010 | 07:21 PM
f22vtec1's Avatar
plugged hole with a 12mm bolt and still no change :-( ****k
Old Nov 16, 2010 | 07:57 PM
egkingfl's Avatar
what ecu u r u running
Old Nov 16, 2010 | 10:12 PM
f22vtec1's Avatar
socketed p28 same one for 3 years
Old Nov 17, 2010 | 02:09 PM
f22vtec1's Avatar
no other ideas people ? thanks so far
Old Nov 17, 2010 | 08:09 PM
f22vtec1's Avatar
bump!!!
boostedjdmdc2
13
Oct 27, 2021 06:48 PM
carlos8
Nov 21, 2013 07:45 AM
civicef990
Nov 21, 2011 04:14 PM
Spawne32
Jul 9, 2011 05:08 AM
RDAYA0
Jul 17, 2008 03:47 PM
