B18b swapped 92 hatch with CEL codes 10, 21, & 41 and also low mpg
Old Nov 15, 2010 | 11:00 AM
TNFRex's Avatar
Default B18b swapped 92 hatch with CEL codes 10, 21, & 41 and also low mpg
so i just bought a b18b swaped 92 vx hatch and it idles like crap and running rich as all hell...i drove for an hour and used half tank of gas...it has check engine light on so i jumped the plug by the ECU and pulled the codes
21= VTEC spool solenoid valve
41= primary oxygen sensor
10= IAT intake air temperature sensor
would fixing 41 and 10 fix my crappy idle and excessive fuel consumption?
and why am i getting a code 21 when its not VTEC?
any help would be greatly apprecieated
thanks
Old Nov 15, 2010 | 11:07 AM
Former User's Avatar
Default Re: just bought b18b swaped 92 hatch...NEED HELP!
Codes 10 and 41 would generally increase fuel consumption. Are those two sensors plugged in and properly pinned to the ECU?
Old Nov 15, 2010 | 11:29 AM
94EG8's Avatar
Seagull Management
Default Re: B18b swapped 92 hatch with CEL codes 10, 21, & 41 and also low mpg
It addition to what Ron said you might want to see what ECU you have in there. And what was used for an O2 sensor.
Old Nov 15, 2010 | 11:40 AM
fv8s's Avatar
is this a p-75 ecu that you are using?
Old Nov 15, 2010 | 12:29 PM
TNFRex's Avatar
its a P72 integra GSR ECU
Old Nov 15, 2010 | 12:31 PM
94EG8's Avatar
Seagull Management
Well that would explain the vtec code.
Old Nov 15, 2010 | 12:41 PM
94EG8's Avatar
Seagull Management
You could also use an OBD1 PR4 ('92 - '93 Integra RS/LS/GS ECU)
Last edited by Former User; Nov 15, 2010 at 12:42 PM. Reason: Removal of WTB post - just clean up. You did nothing wrong.
Old Nov 15, 2010 | 12:49 PM
TNFRex's Avatar
ok thanks, i have to see if the one i have is OBD2 or 1, then i can go from there
Old Nov 15, 2010 | 12:53 PM
TNFRex's Avatar
whats the best way to figure out if i have OBD1 or 2?
Old Nov 15, 2010 | 01:05 PM
HondaPartsHero's Avatar
Technical Hero
From top to bottom:
OBD2B
OBD2A
OBD1
OBD0
joes-92
26
Mar 20, 2013 05:17 PM
Twilightepitaph
Oct 20, 2009 08:01 AM
dc18rb
Jun 20, 2007 10:34 PM
BoRiCuA
Nov 30, 2004 01:23 PM
11secdx
Jan 20, 2002 09:37 PM
