Stripped Rotor screws on 2007 Accord
What's the best way to remove screws that are stripped on the rotor? I was about to change my friends rotors and got the tire off and the screws were stripped. How do I remove those stripped screws?
I usually use a punch or air hammer to get the threads to let loose of the disc. Then drill a hole in the center and then use an easy-out or similair tool. You may have to re-tap the threads when all said and done. Or just grind the broken threads flush with the hub and don't use a screw when replacing the disc.
Those screws are the biggest headache when they don't come out, haha. But yeah as Eskie said, the best way is to just drill them out and not to replace them. Just use a lug nut to hold the rotor in place when reinstalling the caliper and pads.
Snap-On has a sweet attachment for an air hammer for removing them before they get stripped, When I worked for Honda a couple of the other guys had them and they worked really well. Once they're stripped though drill them out.
Yea those are nice. To bad I wont buy any more snap-on tools. LOL I use a center punch and a hammer to turn them out. (or snap em off on the really gnarly ones)
I had this problem on my wife's Fit, and I got impatient and just drilled them out.
For rotor screws, a cold chisel will also work. Center punches are relatively cheap, some only $1 - $3.
duwa
Apr 22, 2009 12:27 PM
jdm-hondacura
Nov 17, 2006 05:24 PM
integra7
Dec 4, 2001 12:41 PM
