odb1 b18 in a 98 civic hatch
Old Nov 14, 2010 | 10:17 AM
sircivic902's Avatar
Default odb1 b18 in a 98 civic hatch
im putting a odb1 b18 in a 98 hatch, wat is the easiest way to wire the engine ive been told to use the civic harness n ive also been told to use the integra harness can anyone help?
Old Nov 14, 2010 | 12:11 PM
habib's Avatar
Default Re: odb1 b18 in a 98 civic hatch
You will need to run the civic harness. For less hassle i would change your distributor, alternator, and injectors to obd2 so you wont have to cut any of your wires on your harness
Old Nov 14, 2010 | 12:13 PM
the integra harness splits after it goes through the firewall, i was told i only need to wire a couple of the wires on the split to get the car to run if i use the whole integra harness???
i know if i use the odb2 harness i have to change some of the sensor plugs etc.. but im trying to find a diagram so i can wire the harness onto the integra plug, so i can use the integra computer. im wondering if there is a diagram so i dont have to buy a conversion harness
Old Nov 14, 2010 | 12:16 PM
i already wired the dizzy n injectors n all the sensors for the odb2 harness. harness is pretty much all attached to the motor, i just dont have a conversion harness to use the integra computer??
Old Nov 14, 2010 | 12:23 PM
habib's Avatar
If you are using the obd2 harness and the integra obd1 ecu then all you will need is a obd2>obd1 jumper harness
Old Nov 14, 2010 | 12:28 PM
i wanna wire it myself lol would rather learn how to do it myself, then buy the conversion harness
Old Nov 14, 2010 | 12:29 PM
jayWknight's Avatar
You have a lot of learning to do. The 2 piece engine harness that breaks at the shock tower in the 94-01 integras,92-95 civics do not exist in 96-00 civics. The engine harnesses in the 96-00 civics are one piece. You will have to reuse the original engine harness and extend a few plugs. For the swap simplify, you will use a obd2 distributor, fuel injectors and alternator for the b18. You will also have to do a 3 wire to 2 wire iacv conversion. In order for the ecu to work, you will need a obd2a to obd1 jumper harness.
Old Nov 14, 2010 | 12:30 PM
jayWknight's Avatar
Well the reason why this will not work. Obd2a ecu connectors are different from obd1 ecu connectors. The conversion/jumper harness is a must.
Old Nov 14, 2010 | 12:38 PM
so its impossible to make your own jumper harness??
Old Nov 14, 2010 | 01:08 PM
jayWknight's Avatar
It is but you need a spare obd2 ecu to take the connector from and then you need the obd1 ecu connectors from the interior of a 94-95 integra or a 94-95 civic. I rather pay 30 - 60 bucks then to make one. I have made one before, is not worth the time.
Old Nov 14, 2010 | 01:37 PM
i have all the connectors just need a diagram n i would have to order a conversion harness, have asked a couple shops n they say i gotta order it online, so who knows how long that would take to get it or if i even get it lol so id rather just make it myself n not waste the time n money waiting for one not to get here
Old Nov 14, 2010 | 02:20 PM
anyone know where to find a diagram???
NotAJDMFanBoy
Aug 6, 2011 01:26 PM
D_koschak
Jan 21, 2011 05:46 PM
v-tec maz
Jan 8, 2006 07:01 PM
Ezrider_03
Oct 18, 2005 12:01 PM
