Main relay?
Old Nov 13, 2010 | 03:55 PM
accord2civic2prelude's Avatar
Default Main relay?
What will cause a car to have power when the battery is connected but the key isnt in?
I had my negative terminal off when trying to wire up my external coil to the dizzy. When i put the negative terminal back on, the fuel pump primes and the gauge cluster lights up as if the key was turned to thh on positiong. What could this be?
Old Nov 13, 2010 | 04:27 PM
Default Re: Main relay?
anybody
Old Nov 14, 2010 | 09:28 AM
Former User's Avatar
Did you cut and splice the wrong wires?
Old Nov 14, 2010 | 11:29 AM
i think i did, but i took everything that i put on off.
Old Nov 14, 2010 | 12:13 PM
habib's Avatar
Vehicle?
Old Nov 14, 2010 | 01:46 PM
sorry...
94 civic ej2 w/h22a1 swap
i check all fuses, unplugged the ignition switch harness(both) from under steering column. i unplugged all 3 shock tower plugs. funny thing is, when all 3 are unplugged, the gauge cluster(brake and check engine) lights are still on. when i plug in the 2nd largest, the fuel pump primes. what else should i check?
Somalie187
Feb 17, 2013 12:47 PM
radicaled434
10
Apr 27, 2012 04:10 PM
Nov 15, 2010 11:09 AM
BlkB16EK9
Mar 27, 2006 07:21 PM
