eg b18a1 at/mt swap starting problem
Old Nov 12, 2010 | 01:28 PM
dumped94'4door's Avatar
Default eg b18a1 at/mt swap starting problem
i just recently got my car all back together from doing the swaps. i went to start the car and nothing happens. the starter doesnt try to engage or anything. is there some type of bypass that i have to do with the neutral safety switch? the car has power for headlight and the blower works. the lights dim slightly when i turn the key like its trying to start. if anyone could give me some kind of direction to try and find the problem i would appreciate it.
thanks
ps. im new to the honda scene so im not to good with them yet
Old Nov 12, 2010 | 02:08 PM
slowhatchcali's Avatar
Default Re: eg b18a1 at/mt swap starting problem
you need to install the neutral safety switch wires to a clutch switch, which bridge the connection and provide continuity for the starter to crank, or, if you're brave enough you can just bridge the two wires together and be done.. that will cause your starter to crank the engine without the need to depress the clutch..
the two wires are found in the big white plug that plugs into the shifter assembly for the automatic shifter... they're the two middle wires on the plug, not sure about the colors off the top of my head, but theyre pretty thick gauged..
Old Nov 12, 2010 | 02:12 PM
thank you. i figured i needed to do something like this. i have the book so ill look up what wires they are.
Old Nov 12, 2010 | 02:16 PM
no problem..
Ztv651
Sep 26, 2017 05:25 AM
ferio-ichi3
Apr 2, 2013 01:46 PM
AlfieRoach
Jun 17, 2010 05:47 PM
JDM-EJ1
10
Jul 30, 2005 09:39 AM
thecorey
Mar 12, 2004 07:05 PM
