cluster light fuse and tail light keep blowing
Old Sep 21, 2002 | 03:26 PM
chirp2hrd's Avatar
Default cluster light fuse and tail light keep blowing
what could this be they instantly blow when i replace the fuse for taillight, parking light and cluster?? what culd it be?
Old Sep 21, 2002 | 03:38 PM
allmotorEG-SI's Avatar
Default Re: cluster light fuse and tail light keep blowing (chirp2hrd)
you have some wires touching. Go thru every wire and check to make sure they're not touching. I had the same problem and it was the liscense plate wires. The plugs the bulbs go into got squashed in between the bodykit and frame.
Old Sep 21, 2002 | 03:52 PM
chirp2hrd's Avatar
Default Re: cluster light fuse and tail light keep blowing (gixxerdemon)
what wires should i check
Old Sep 21, 2002 | 04:07 PM
on my crx there is a diagram on the inside cover of the dash,you know, the onethat folds down to reveal the fuses. It tells what each fuse is hooked up to. I simply inspected all the wires I could get to for all the listed componets.
Old Sep 21, 2002 | 05:07 PM
chirp2hrd's Avatar
yes i checked and dont see anything wrong what was your problem
Old Sep 21, 2002 | 05:37 PM
the socket that held the liscense plate bulb was crushed causing the 3 wires in it that normally never touched to be all squished togather and caused a short and a fuse to blow every time the headlights turned on. Maybe somthing on your car isn't grounded. I would glady help you take a look but I doubt ricetown is anywhere near costa mesa or anaheim.
Old Sep 22, 2002 | 05:28 PM
chirp2hrd's Avatar
what grounds should i check for i looked at the tail light cluster and front cornors noothing seems to be wrong i dono bout the liscence plate tho
Old Sep 22, 2002 | 07:14 PM
chirp2hrd's Avatar
ttt any one know why that fuse would keep blowing ???
Old Sep 23, 2002 | 01:15 PM
what do you mean you don't know about the liscense plate thing. I'm pretty sure thats connected to the same fuse. if you can get to it, the wires can just seperate so do that and see if it works. I'm guessing you need to check the diagram and see whats all conected to the fuse. Find which of the componets is always on and disconnect it that n put in another fuse and see if that helps. The reason I say something that is always on is because when I had a similar problem. the fuse would only blow if I turned on the headlights but if they were off the fuse was fine. So definitly look at the diagram and CAREFULLY examine every part of the things hooked up to that fuse.
Old Sep 23, 2002 | 04:11 PM
chirp2hrd's Avatar
i checked my liscence plate and nothing wrong i replaced my corner lights plugs and checked my tail light i dont see anything worng it went on and 2 seconds later it blew i dono its pissing me off please help
Old Sep 24, 2002 | 12:07 PM
seekerONE's Avatar
obviously you have a short...the most common cause of this is wiring from the aftermarket stereo....wire in adapter harness usuallly not using lighting connection.....all of the ones i have had to fix the wire color is orange. if it is not being used tape it off so it doesn't ground out and blow fuse.
or possibly aftermarket guages...(eg indiglos) wired up wrong
or those stupid led washer squirters
Old Sep 24, 2002 | 03:28 PM
CRexcellence's Avatar
New User
Default Re: cluster light fuse and tail light keep blowing (seekerONE)
i had the same problem, i tore the car appart and never found the short, but when i put it all back together the fuse never blew again.....weird huh?
Old Sep 24, 2002 | 08:02 PM
chirp2hrd's Avatar
Default Re: cluster light fuse and tail light keep blowing (jrx2002)
seekerone your are a great great man i cant belive you hit it right on the money it was E X A C T L Y what you said the orange wire on my aftermarket headunit was touching metal your are smart as hell man thatnks i am so much happier now
Old May 17, 2010 | 04:14 AM
elbear's Avatar
Always a short.
Old May 17, 2010 | 05:05 AM
sfetech01's Avatar
CHECK YOUR CIGARETTE LIGHTER
ajason24
36
Jun 4, 2009 05:14 PM
kelviiv
May 18, 2008 10:22 PM
Streetdreams022
Jan 8, 2005 08:20 AM
becones
Apr 18, 2003 11:38 AM
