Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
bought an odyssey with bad trans have questions
Old Nov 11, 2010 | 06:41 PM
moto500's Avatar
Default bought an odyssey with bad trans have questions
Today i bought a 2001 odyssey,125k and its nice. was advertised as having a bad trans. good thing it was only 2 miles away. I called the former owners mechanic(she had it in last week for misc maint,thought they were having belt noise..) and he said that the code that came up was torque converter. He said this was a $500 job. sounds good. It acts like it hits neutral when it shifts.. as a new owner, reading all these posts, whats the problem with these trans? What part is failing? Is it lack of oil? Can a newer trans fit and would last longer?
This guy cant see it until next week, so im gonna do the oil change and see what happens with the honda oil. (maybe it had something else in it)
He also said that she had a new trans put in at 80k(warranty?)
My local dealer quoted 3k for a new trans with 3 year 36k.
I have found a 2010 trans for 1100.00 will this fit?
Thanks guys
Old Nov 14, 2010 | 08:25 PM
moto500's Avatar
Default Re: bought an odyssey with bad trans have questions
The d4 light is not coming on at all. Im hoping this is just a solenoid. Does anyone know a way of testing these?
Old Nov 16, 2010 | 04:20 PM
94EG8's Avatar
Seagull Management
'99 - '01 transmissions are internchangeable, the '02 - '04s are 5 speed automatics. The '99 - '01s failed due to a bearing failure (bearing flew apart and fragments plugged up passages and causes erratic shifting. '02 - '04s had problems with the 2nd and 3rd gear clutch packs. Most of these odysseys are on their 3rd or so transmission at this point. A lot of them failed at 80 - 120k.
Old Dec 17, 2010 | 05:43 AM
Myroslav69's Avatar
The above info is correct. I had the same thing happen to my trans, I just took it in for a full rebuild. It cost me $1600. If you buy a trans from a junk yard, you will pay $1000+, and there is a chance that that trans will also fail quickly. I would just get it rebuilt and be done with it. I have 2 Odysseys, love them both, and had the trannies rebuilt in both. I tow a 5000lbs trailer almost on daily basis with my van, never had an issue since rebuilt. It's been 30000 miles.
Combatlouie
Transmission & Drivetrain
Nov 19, 2013 06:20 PM
datkid_dino
Apr 2, 2013 10:31 AM
unusual71
Nov 27, 2010 09:27 AM
tomstock202
Dec 3, 2008 07:46 PM
Probot
Jan 4, 2008 04:22 AM
